Dual headlights
- DasTeufel
Re: Dual headlights
05 Dec 2005 19:19
Well, after investigating a few options, I'm not going to go dual headlights. I am, however, going to use a single oval shaped driving/fog lamp that I will mount under the fork brace. I will wire up it's own circuit with relay and switch and operate it when I need that extra splash of light at night. For circuit, I was considering a power relay that would engage power when the key is turned on, feeding a relay that would turn on when I flip the switch for the lamp. Will the charging system be enough to operate the lamp when I need it?
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
Wildomar, CA
- loudhvx
Re: Dual headlights
06 Dec 2005 10:48
If it's in the 55W range, it shouldnt be a problem.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- DasTeufel
Re: Dual headlights
06 Dec 2005 12:03
Good to go! With it being on it's own circuit I don't think there will be much of a problem either, just needed confirmation! Thanks!
2009 KTM 690 SMC
Wildomar, CA
Wildomar, CA
