Another Starter Clutch Post
- Sixgun
I've been looking in my manual and it doesn't look too involved on the 750 B3. I've read other posts on how you have to go in from underneath the bike and I'm just making sure I'm reading my manual right. It looks like a big project on other bikes.
As far as the manual shows on my bike its just behind the dynamo rotor on the left side of the bike. Is this all I need to do to get to it on the 750. The only thing I'll have to get is something to hold the flywheel while removing the mounting nut. Thanks to Biquetoast I have the cross reference for all the other Kaw's that used the same clutch and there are quite a few.
Let me know if I'm looking at this way to easy for those of you who have done it before.
Thanks for the assist.
78 KZ750 B3
81 XS650SH
80 XS650G
- steell
IIRC the rear axle works nicely as a rotor removal tool, just thread it in as tight as you can get it then smack the end of the axle with a hammer. It should pop right off.
- apeman
- Thank you received: 3
I have heard that the procedure for starter clutch repair for the 2 cylinder models is much easier.
Petaluma and Truckee, CA -- member since Jan. 23, 2003;
PREVIOUS KZs: 1980 KZ750H with 108,000 miles; 1980 KZ750E with 28,000 miles; and KZ750H street/cafe project, all sold a few years back.
This is what I do for fun, not for work. It is art, with a little engineering thrown in.
- Sixgun
78 KZ750 B3
81 XS650SH
80 XS650G
- steell
If you are lucky the sheet metal cover on the starter clutch has not slipped and covered the three hex head bolts that hold the clutch to the rotor.
- Biquetoast
- King Jeremy The Wicked
Remember, the parts might not be the only problem. It could be that the surface has worn unevenly as well. There's a very nice chap offering a lathe service on the lonesometwin.co.uk forum, if that turns (pun very much intended) out to be your problem.Thank you gents. Now to find the parts. Kawasaki used the same clutch from for the twins until 1984. Thanks for the help.
On the other hand, if it *is* just the rollers or springs or whatever, and you *do* manage to find a source...or rather an *affordable* source... of the parts, make sure to let us know! I have 4 bikes that need this work...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
- Biquetoast
That reminds me......If you are lucky the sheet metal cover on the starter clutch has not slipped and covered the three hex head bolts that hold the clutch to the rotor.
Steve (a.k.a. Lonesome), at the aforementioned LonesomeTwin.co.uk forum, just had his three hex head bolts come loose and wreak hell inside of his engine. If you get a chance, go over there and check out the damage. MAKE SURE that you tighten those suckers when you're done, and for god's sake man use a threadlocker... red... or stronger if they make it...
kz750twins.com
- steell
He's not alone, I have a 76 750B1 motor that had the same thing happen, wiped out the stator, starter chain, starter clutch gear, and rotor. No damage to the case so it wasn't a big deal for me (I have lots of spares).
- Sixgun
I'll let you know how it goes
Here's Rice Paddy's number if you need it.
1-877-460-1404
They've been a good source of odds and ends parts for me. He said he had at least 20 bikes at their yard that used that clutch.
Thanks
Post edited by: Sixgun, at: 2007/01/04 14:30
Post edited by: Sixgun, at: 2007/01/04 15:36
78 KZ750 B3
81 XS650SH
80 XS650G
- cjhansen2
- Visitor
- Sixgun
BikeBandit.com had the rollers and springs for a pretty good price.
Rollers are $6.10
Springs $2.65
This would beat the $80 it would cost to buy one at the bike graveyard. It looks like if I rebuilt it with OEM parts from BikeBandit it would run around $130. Not too bad for brand new.
78 KZ750 B3
81 XS650SH
80 XS650G
- Biquetoast
Make sure they actually *have* them. I've ordered stuff that went through fine until they went to actually *get* it, then they told me it was no longer available....BikeBandit.com had the rollers and springs for a pretty good price....
On the other hand, they are one of the best last resorts for parts...
But like I said, it may be your surface, and not the roller...
Keep us posted!
kz750twins.com
