A Syncing feeling
  • kzwolfsr
  • kzwolfsr's Avatar Topic Author
A Syncing feeling
15 Dec 2006 05:49
#99733
Would my number 2 carb being out of sync cause it to just flood fuel into the cylinder?
Original man of the Caribbean
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: A Syncing feeling
15 Dec 2006 05:52
#99734
No but a malfunctioning vacum petcock would.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
15 Dec 2006 05:59
#99738
Or perhaps a float needle not properly seating.
  • kzwolfsr
15 Dec 2006 07:30
#99754
The petcock is ok. I mean during riding. Ya see I pulled of my head and on no.2 that wasnt firing there was this long clean stripe where I see the fuel and carb cleaner has cleaned that part in the valve area. I took apart my carbs last night and cleaned them and 2 was out of sync a bit so I fixed that. I cleaned my carbs in the whole bottle of carb cleaner (gumout) and itworks really well and it has this lubricating quality to it so when I was putting the carb slides back in, they went in without a hitch.I have pics to show
  • kzwolfsr
15 Dec 2006 07:30
#99755
my carbs
  • kzwolfsr
15 Dec 2006 07:53
#99758
Also to WG, my main jets do have the number 56 on them. They have the R, the square, then on the other side it just says 56. Itried taking a pic of it but its to small.
  • The Gringo
15 Dec 2006 16:35
#99867
As long as you already have the carbs all ripped apart anyway check to see that your petcock is shutting off. You have a vacum petcock so without the engine running with it either in the reserve or on position no gas should flow out of it.
I have also had good luck with using Mothers mag polish on the end of a Q-tip to clean up any residial crud that may be in the brass part of the needle and seat. Just dip the Q-tip in Mothers and spin it around in the seat area till the brass gets nice and shiney.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • kzwolfsr
16 Dec 2006 07:27
#99971
I hear ya
  • pumps
  • pumps's Avatar
16 Dec 2006 16:19
#100051
Just seeing PICTURES of all those little parts makes me start squinting..I getting to that age where my arms need to be longer......:laugh:
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
  • kzwolfsr
16 Dec 2006 16:26
#100054
the pic used to be like 10 times the size of that one but i had to reduce the kbs. Hows your bike running? If good, good for you, my head is off right now and my parts were delivered yesterday but i wasn't home to get them , so I have a long wait till tuesday.
  • pumps
  • pumps's Avatar
16 Dec 2006 16:52
#100059
Today we had unusually warm weather..middle 60s. I rode about 100 miles today. Mostly on the KZ but some on the Virago too. It was wonderful therapy for my mind. Installed a pigtail for a Battery Minder on the KZ so I can keep it charged.
1977 Yamaha XS650
2000 Kaw W650
  • kzwolfsr
16 Dec 2006 16:54
#100061
Cool!
