Kz440 Vacuum Diaphragm
  • Irish1
  • Irish1's Avatar Topic Author
13 Dec 2006 18:52
#99395
I'm new to the Kzrider site, and was looking for some help possibly.
I have purchased an old '80 kz440 cheap.
Being a project bike, I decided it's going to be a hardtail bobber when its done.
Heres my dilema:
before I bought it, the bike had been sitting quite a while so it needs alot of work all around. Currently I'm trying to track two diaphrams for the carbs, as one is torn and the other has a small pin sized hole in it, but I am having absolutley no luck in finding the replacments.
Can anyone point me in the right direction?
I've scoured e-bay for weeks with no luck, and visited alot of dead end online stores.
Any help would be greatly apprecaited.
Thanks in advance!
Irish1
99 Custom built Softail (project)
80 Kawasaki kz400 Bobber (project)
82 Yahama xj650
  • JR
  • JR's Avatar
Re: Kz440 Vacuum Diaphragm
13 Dec 2006 19:47
#99420
Have you looked at these guys www.nrp-carbs.co.uk/ ?
They are located in the UK and I beleive the idea is that you send them your old units and they fit new diaphragms for you. I have never used them but have heard they are reasonable.
You may also want to check www.kz400.com
If you are rebuilding you will find this a great resource.
Welcome to the forum, good luck with the project and make sure to post some photos for us.
  • Irish1
14 Dec 2006 05:17
#99499
JR
Thanks for the URLs, I think that is exactly what I'm looking for.
I knew I joined Kzrider for a reason!
Thanks again I appreciate it!
I'll post some pics as soon as I take 'em.
Irish1
Gardiner,ME
82 Yahama xj650
  • kzwolfsr
  • kzwolfsr's Avatar
14 Dec 2006 12:04
#99590
You Can also check z1enterprises.com. I just ordered my diaphragm kit from them for my 650 and it only cost $25.
Original man of the Caribbean
  • flht1997
  • flht1997's Avatar
14 Dec 2006 15:16
#99610
torn diaphragms is standard equipment on a 400 :) they are near impossible to find. seen the site for the place in england but i never tried them. i have two good set for my 400's and one so-so set (patched diaphragms) small pinhole may be ok, but a rip is a no go. generally it is just neglect that will kill a 400. get the carbs sorted, new plug, clean/replace your points, and it should run.
pic is just for referance of two known working sets :)
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • Irish1
18 Dec 2006 14:08
#100324
Looks sharp flht1997!
Thanks everyone for all the advice. I've got the bike right down to the bare the frame right now, and I am going through and meticlously cleaning the engine.
The guy who owned it before me, looks as though he used it for a field bomber
:unsure:
I'll post some pics as productions persists.
Irish1
Gardiner, ME
82 Yahama xj650
  • flht1997
  • flht1997's Avatar
18 Dec 2006 15:40
#100336
let me know if you need specific pictures. i am doing two right now. 400 cafe/bobber thing, then all the left overs are going to a 440 dirtbike. these newer 400/440 are just so darn simple to work on. main thing is getting the carbs working, good intake boots and a good 12v to the coil.
does your 80' have a six speed? or is it still a 5.
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
  • Irish1
19 Dec 2006 05:33
#100459
it's a got 6 speed in it. (That thing got a Hemi?) J/K
Are you leaving the orginal frame for your bobber project? I'm actually looking at "weld on" hardtail section that bwchoppers.com offers. My biggest concern is getting everything lined up properly. I can weld no problem, but have major concerns about chain alignment wheel alignment ect.
:S
Irish1
Gardiner, ME
82 Yahama xj650
  • chetriply
  • chetriply's Avatar
20 Dec 2006 09:13
#100676
If you go to the Horse Backstreet Choppers site there is a great article with pics on how to hardtail a Japanese four frame. The one they use is a CB but it will work with your frame. It's under "articles" and is titled "Hadrtail Your Japbike".
  • Irish1
20 Dec 2006 10:03
#100689
I checked out the site.
What a great method for alignment!
Awesome thanks for the tip chetriply!
Irish1
Gardiner, ME
82 Yahama xj650
  • flht1997
  • flht1997's Avatar
20 Dec 2006 10:04
#100691
if your worried, just leave your swingarm in, use your old axle plates and weld you hard tail to them, then cut out your swingarm. on my hard tail i just welded struts into it and left the in the swingarm, never to swing again. the others all have shocks. my back is/has been in constant pain for awhile now so there is little hardtail riding in my future
Matt Milwaukee, WI
89' BMW R100RT
06' KLR650
