CV34 hole in slide diaphram causes what?
  • DanAir
  • DanAir's Avatar Topic Author
09 Dec 2006 06:12
#98409
What result would one expect from a hole in a slide diaphram on a CV34 carb? Rich? Lean? Hesitation? Nothing? Anything?
Thanks in advance.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: CV34 hole in slide diaphram causes what?
09 Dec 2006 06:26
#98412
Rough running and poor performance. One cylinder won't pull gas in at nearly the same rate as the other three; the symptoms depend on the size of the hole and the hole location.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
09 Dec 2006 08:20
#98431
I have heard of people repairing them with some sort of glue. I bet WG can "fill" you in on this one.;)
'85 GPz550(ZX550-A2)
  • guitargeek
  • guitargeek's Avatar
  • Elitist, arrogant, intolerant, self absorbed.
09 Dec 2006 11:02
#98481
I ain't touching this one...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
  • RonKZ650
  • RonKZ650's Avatar
09 Dec 2006 15:34
#98561
My Goldwing had 2 bad and basically what it did was act like it was only running on 2 cylinders while going down the road. Replaced those 2 for close to $400, being too cheap to anty up for all 4. Next season, running on 2 cylinders again, so $400 for the other 2. Heaps of work involved on this stupid Honda and I should have replaced them all. If one is bad the others are on their way out.
  • DanAir
10 Dec 2006 09:19
#98684
Thanks for the info! What is that secret substance that can be used to repair a small hole in a slide diaphram?
Thanks again!
  • guitargeek
10 Dec 2006 09:51
#98690
  • DanAir
10 Dec 2006 10:37
#98705
Found the answer after searching the forum for awhile.
"I know nutting....My lips are sealed." Sgt. Shultz:whistle: :P
  • whizzer
  • whizzer's Avatar
24 Jan 2007 11:39
#107892
LOL!! This sounds exciting! What's the answer?!!
