Newby question
  • xsjunky
  • xsjunky's Avatar Topic Author
Newby question
23 Nov 2005 07:47
#9812
Before I start bothing everyone with repetative questions, is there a location here at KZR or off site to find lots of per model tech info like what, if any, other year carbs fit the 77 kz1000 ltd.
  • fergyfer
  • fergyfer's Avatar
Re: Newby question
23 Nov 2005 09:21
#9826
Hopefully someone with the cross reference guide for that model will chime in here. Good luck!
  • xsjunky
Re: Newby question
23 Nov 2005 21:31
#9947
It looks, from the Kaw site, that 77 and 78 carbs are interchangable. Please correct me if I am wrong.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Newby question
24 Nov 2005 13:03
#10034
Any carburetor assembly from 73-80 will fit any Z1/KZ900/KZ1000 from those years because both venturis have about the same size (will fit manifolds/air box without mods and the carb spacing is the same. In other words, you can use any Z1 (Z1/Z1A/Z1B) carb, any 76/77 KZ900 VM26 or any 77-80 KZ1000 assembly on your bike. If you bike has stock airbox/pipes, stay with the stock jetting for the particular assembly in question. If you have made modifcations, then ask about rejetting.
