Need a bs34 carb
  • gpzrox
  • gpzrox's Avatar Topic Author
Need a bs34 carb
02 Dec 2006 13:18
#96825
Simple story: Carbs overflow majorly after a good cleaning. Figure that needles aren't seating properly, remove a float pin that I must have put in wrong: pin holder broke.
Gonna work with some J weld or something, but want to replace the carb.
Now considering that it was the outside carb, opposite the choke side, I imagine that I could use the carbs from several different models, lets say some of the 1000 series Kawis, and maybe some of the twin Yamahas. Am I correct in thinking this.
I know that I would change the internals to what I have, but the outer body should be the same, right, as long as it is the correct side.
Thanks guys. I am almost physically sick right now, but I will work through it.
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Need a bs34 carb
03 Dec 2006 13:46
#97067
First, the air jets on the various BS34 carbs are different sizes and you will have tuning problems if you stick a carb from some other type assembly. Get one that matches your set. Next, you can use any of the four carburetors if you remove the arm that goes through the butterfly and swap the butterfly and arm stuff in. The only thing you will have to account for is the fuel flow. The 2 and 3 carbs have holes in both inlets so if your "new" carb doesn't have a hole where it is supposed to, you can drill a hole to where gas hits the seat using a 1/8" drill bit. You may have to JB Weld one side if gas flow isn't appropriate. The nice thing about 34s is that all all carbs from the same assembly are essentially the same EXCEPT the gas holes.
  • gpzrox
04 Dec 2006 03:15
#97295
Thanks Wired. I'll mull over that.
LP
