Vacuum Petcock
  • vasnico
  • vasnico's Avatar Topic Author
Vacuum Petcock
26 Nov 2006 19:22
#95202
I've read the topic on petcock issues, my question requires a little more detail. The bike is a KZ1000 '78. To which carburator is the vacuum line typically attached?
  • KB02
  • KB02's Avatar
Re: Vacuum Petcock
27 Nov 2006 05:26
#95295
Well, I know that on my '80 550, it is attached to Carb #1. I think that some models attach to carb #2, though. There should be an open nipple near the front of the carb for the line to plug into. It should kinda stick out as only one carb will have it (the other three will noy).
  • pyxen
  • pyxen's Avatar
Re: Vacuum Petcock
27 Nov 2006 05:44
#95303
mine's attached to #3 - so I guess it'll be necessary to check the manual. ;)
84 KZ550-F2 LTD
93 ZR550-B4
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Vacuum Petcock
27 Nov 2006 06:03
#95310
See the "VM Carb Connections" link on my web site. I suspect carb #3 is the vacuum fitting. The other two are vents and MUST NOT be obstructed.
  • vasnico
Re: Vacuum Petcock
27 Nov 2006 17:56
#95459
Hey guys, thanks for the input and wiredgeorge I checked out your website and found your information very useful. Later.....
