REFUSES TO START
- kawadruida
Re: REFUSES TO START
29 Nov 2006 12:45
Wiredgeorge/Stpauler: Thanks for chiming in! I´ve heard from Z1 enterprises in this forum and browsed their website a few times. Will ask if they have the carb boots for my bike, how much they cost and shipping costs/time.
BTW, the boots are different -apparently- than those for your bike, Stpauler: buykawasaki.com lists them as 14073-1158, even if in the diagrams they look pretty much the same.
Thanks again folks, will keep you posted!
- pyxen
30 Nov 2006 07:34
kawadruida wrote:
Hey..sorry to disappear on ya. Yeah, that's pretty much it. You can add a little bit more so that you can be sure it covers it, but 1cm will definitely do.
Hope it works! Its cheap, and effective - a damn good combination!
Thanks Pyxen! You just showed me the light! Can´t wait to go to the bycicle shop to get my own inner tube!
As I understand, you "wrapped" the boots with the inner tube pieces, allowing about 1 cm. of "free inner tube" to slide over the carb, right? Simple, clean and good looking too!
Thanks again man.
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- kawadruida
30 Nov 2006 16:12
Pyxen, thanks again man. Just got my inner tube today, this weekend I´m gonna work in my carbs,put the "overboots" on
and see what happens. If all goes well, I´m taking her for a spin on sunday.
I´ll post my results and a couple of pics of my reborn GPz.
Wish me luck!
Wish me luck!
- kawadruida
03 Dec 2006 15:43
This is what my carb boots look like. I can´t believe these rock-hard things were soft and actually made of rubber sometime in the past...
As you can see, their condition is just miserable, don´t you agree? I think I´ll file and sand the boots lips to smoot things out and slip the inner tubes a little easier.
Just took the carbs off, gonna disassemble them, take a good look (especially at #2) clean them again with carb cleaner and pressurized air and hope this time all goes well.
Wish me luck, I´ll keep you posted.
PS: You can see better pictures of my ride and the new paintjob (including details) in the Paint & Bodywork Forum.
Post edited by: kawadruida, at: 2006/12/03 18:45
- pyxen
03 Dec 2006 19:01
wow..those're definitely out of shape.
Hope you get it fired up soon!
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- trippivot
06 Dec 2006 06:30
use a hair dryer or heat gun to get the hard rubber pliable that will save the skin on your knuckles
- kawadruida
06 Dec 2006 11:02
Trippivot, thanks for your advice, but I will do the inner tube trick and leave those boots as they are now.
Cheers
Cheers
- kawadruida
09 Dec 2006 09:41
A couple of pics before putting things back together.
The inner tube "overboots" already installed...
- kawadruida
09 Dec 2006 09:43Attachments:
- pyxen
09 Dec 2006 19:22
Good luck!
Hopefully the fact you haven't posted means you're out riding!
Btw - next time you have the bike apart/tank off, you may want to put a fuel filter on your gas line.
Post edited by: pyxen, at: 2006/12/09 22:25
84 KZ550-F2 LTD
93 ZR550-B4
93 ZR550-B4
- kawadruida
10 Dec 2006 15:48
No, I haven´t posted because I was too busy cursing in every language I know, and some others I don´t :pinch: :sick:
Carb leaking stopped (after disassembling and cleaning again) and everything seems fine: timing, spark, fuel flows OK (I already have a fuel line filter installed, thanks Pyxen), but it just won´t start. I´ve even tried spraying liberal amounts of WD40 in the carbs while cranking the engine, but it refuses to start, not even a cough or some sign of life. After several tries, battery lost charge, so I had to quit even if didn´t want to.
I don´t know what else I can do, I´m just about to give up and call a mechanic to bring it back to life, just don´t wanna think about the bill...
- kawadruida
10 Dec 2006 16:50
Just a detail that comes up from my mind: When I disassembled the top end, I marked the exhaust cam just to be sure cams won´t get mixed when reassembling the engine.
When I started putting things back together, I found this illustration in the Clymer KZ500/550 manual, page 258, ENGINE supplement, 1982 and later service information.
But to my surprise, the only way the intake cam sprocket got aligned with the head top & back was with the letter marks upside down. (See illustrtion on next Reply)
I took that as a print mistake and finished assembling the cams. As a precaution I looked at some other pics that showed cam lobe position when aligning cams, #4 exhaust lobe pointing backwards and #4 intake lobe pointing forward (figures 25 & 26, page 70 of the same manual, CHAPTER FOUR -ENGINE) After that and before putting the valve cover back on, I manually rotated the engine several times just to be sure that there was no binding.
Can this be my problem? Maybe I´ve assembled the cams so badly that timing is too far-off? I´m pretty sure that everything was done by the book, but those upside down marks are driving me crazy...
