Starting Question
- bullitt00692
Starting Question
18 Nov 2006 14:01
So what does it mean when my '82 KZ-440 will start when I shoot a few seconds of starter fluid into the carbs. and then dies when the starter fluid burns off?
I have gas getting in the cylinder becuase I can smell it and when I pull the plugs I can see the gas on the plugs? Am I running rich - Can that cause me to not start without the starter fluid?
Any other ideas?
Any other ideas?
- KZQ
- Administrator
Re: Starting Question
18 Nov 2006 17:33
More likely your carbs are full of gelled fuel. Has the bike been sitting?
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- bullitt00692
18 Nov 2006 18:51
Nope - carbs have been removed and cleaned. I did not rebuild or adjust anything - Just removed carbs to clean.
- bullitt00692
18 Nov 2006 18:52
- kzwolfsr
18 Nov 2006 21:13
I had the same problem with my bike. It wouldn't start especially when it was cold and when I checked the plugs, sometimes they would be blowing bubbles with the gas. OK, what I did was that I had my plugs gapped to.035 and I put them back to 31 then, One of my girlfriend's pple did some tuning with the air mixture screws. I didnt no what exactly what he did, if he turned them out or in but after that I didnt have anymore flooded plugs. He did tell me that i wasn't getting enough gas which was confusing to me. What I normally do is put the choke half or 3/4 way up or out so as not to give it to my gas and check also to see that you are getting spark and the right gap on your plugs and try air mix screws, if you know what you are doing
Original man of the Caribbean
- KZ_Rage
- Kentucky Bourbon Barrel Ale
19 Nov 2006 14:49
You might check the choke to see if it is working.
Check for strong spark and the plug gap.
Low spark will work with Diethyl Ether but not with gasoline unless the engine is hot enough to help vaporize the fuel more than when it is cold.
I also assume you have the air box off while shooting the starting fluid in there so that means the air/fuel mixture will be lean anyway.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
1984 KZ550F2 SOLD!
- bullitt00692
19 Nov 2006 19:49
How do I check for a strong or weak spark - I am getting a spark, but don't know how strong it is.
Also, the carb is not connected to the air box, but how will this give me a lean mixture? The carb is still able to suck air.
- wireman
19 Nov 2006 19:52
i would think if its running till ether burns off youve got fire,just not getting fuel;)
- kzwolfsr
20 Nov 2006 11:58
First of all I don't know how you can tell if its a strong or weak spark but I can tell you this. If the spark is small and white, a very thin line, it is weak. I my clymer manual for my bike, is says you are supposed to be looking for a fat blue spark. When your carb isn't hooked up to your air box it gives you a lean mixture because the airbox is basically a air restriction and when you put on pod filters you let in more air, more air than the jets or air mix screws were designed to handle and thus you get a lean mixture. i am not a pro on carbs but you do sound like you need to adjust your air mix srews and check your connections in your wires to your spark plugs. Check around for an ohmmeter and check your secondary resistance, I dont know how the ignition is set up on your bike..... if 2 plugs fire the same time or what but you check resistance by 1 ohmmeter lead in one spark plug cap to the other cap on the same coil
- kzwolfsr
22 Nov 2006 11:58
The guy turned my air mix screws half out To decrease the fuel and bring in more air
