Petcock Issues
- DagoTrojan
Petcock Issues
18 Nov 2006 06:54
Judging from a recent tech article in a magazine, I'm guessing the "vacuum petcocks" like those on my recently acquired '81 550 LTD have some problems. This seems borne out by the fact that mine has plastic petcocks on both the main and reserve fuel lines (I noticed that when they were left open, the carbs would leak fuel when sitting).
Methinks this is a short-term fix, and I'm concerned the plastic 'cocks won't pass state inspection. Is there a better solution? Can I change out the standard 'cock for simpler (that is, "On, Off, Reserve" 'cock like those on my dirt bikes) solution?
Any thoughts would be greatly appreciated!
DagoTrojan
So. Maryland
DagoTrojan
So. Maryland
- OKC_Kent
Re: Petcock Issues
18 Nov 2006 08:19
Check out this link
www.z1enterprises.com/reference/petcock.aspx
You can measure your mounting bolt distance on the gas tank and buy an adapter plate, probably the 34mm one. Get the petcock of choice and a little filing of the tank and your all set. I did mine for about $35. Well worth it. Remember to cap off the vacuum outlet on the carb.
Post edited by: OKC_Kent, at: 2006/11/18 11:25
Cashion, OK
78 KZ650 B2 85,000+ miles
- JMKZHI
Last edit: 03 Dec 2008 11:48 by JMKZHI.
- DagoTrojan
- DagoTrojan
Re: Petcock Issues
19 Nov 2006 04:32
Thanks... I'm going to do some more exploring to see how this thing really works.
Greg aka DagoTrojan
So. Maryland
Greg aka DagoTrojan
So. Maryland
- ambergrismooon
Re: Petcock Issues
19 Nov 2006 05:19
I grew up with on/off petcocks so it is no bother to me. I trust them more too. But my brother can't stand them as he has to remember to turn on and turn off and he figures the less he has to remember the better. I think he has a small harddrive.:pinch: :blink: :huh: :whistle:
