Gasket compression
  • Bluemeanie
  • Bluemeanie's Avatar Topic Author
Gasket compression
14 Nov 2006 17:51
#92150
Measuring the float levek with carbs off the bike, installing new float bowl gaskets. Should I install bowls and torque, then remove and measure floats? Do you think it can make a difference with compressed gaskets? The ones I installed 2 weeks ago seem more compressed then when new... Thanks
  • JMKZHI
  • JMKZHI's Avatar
Re: .
14 Nov 2006 18:10 - 03 Dec 2008 11:49
#92158
del
Last edit: 03 Dec 2008 11:49 by JMKZHI.
