Fuel level...
- Bluemeanie
Fuel level...
13 Nov 2006 06:45
In my factory manual it states Design fuel level 30 +/- 1mm and Service fuel level 3.5 +/- 1mm. Are these figures for the hose attached to the bowl drain or a dry measurment from the gasket?
- wiredgeorge
Re: Fuel level...
13 Nov 2006 08:01
The service fuel level is taken with a hose on the drain to measure the level of the fuel in the bowl. Generally, a float level measurement will also be given and that is made with the carbs upsidedown and level and is the distance between gasket mating surface and top of float.
