Running rich and lean on 2 cylinders
- ron768
01 Nov 2006 16:13
Just put my 78 1000 LTD back on the road and the plugs in the #1 and #3 cylinders are running different from the 2 and 4. The #1 is running rich and no amount of air screw adjustment seems to do anything. The #3 is running lean with the same problem. 2 and 4 are running good with the color I like to see on the plugs ( a light tan). My question is can you run the bike with the clips in different positions on the needles with out a problem in any other area of operation? The engine is stock I have K&N pods installed and a Kerker header with a street baffel.
Post edited by: ron768, at: 2006/11/01 19:14
1976 KZ900 A4 , 1977 KZ650 C1 , 1978 KZ1000LTD B1 , 1978 KZ650SR D1 , 1999 ZRX1100 C3
- 77KZ650
Re: Running rich and lean on 2 cylinders
01 Nov 2006 17:01
have you checked the valves? you may need to re shim. also look for air leaks
07 MDP Rookie of the Year
