26mm carb kits (wg ?)
  • sbjones
  • sbjones's Avatar Topic Author
01 Nov 2006 01:45
#89010
i am starting to look for a complete carb rebuild kit for my 26 mm carbs. i would need all of the parts including choke sets. i am having a problem finding the 26 mm set.
can any one tell me if the 28 mm carbs take the same jets and guts as the 26mm.?
i have gone to z1 and if you look at the part numbers. they have 28 in the number. getting kind of confused.
i will measure my carbs to make sure they are 26's before i go any further.
these carbs will be going onto a basically stock 750 motor into my 650 frame. 28's were going for so much i got these for 36.00. i couldn't pass them up.
thanks
  • wiredgeorge
  • wiredgeorge's Avatar
Re: 26mm carb kits (wg ?)
01 Nov 2006 06:16
#89041
If you have a question about www.z1enterprises.com parts, I suggest you give them a call and ask them as I can't speak for them. As far as just basic info, there are MANY types of VM26 and the internals are different in each type... and they are also different from VM28. I suggest you identify your carburetors before attempting to buy parts and then communicate the type of carburetor to z1enterprises.com if that is who you choose to buy from.
  • sbjones
01 Nov 2006 23:30
#89249
thanks wg. i will contact jeff and see what is up.!!!!!
