VM28 carbs vs. VM29 carbs
  • tw..
  • tw..'s Avatar Topic Author
26 Oct 2006 05:23
#87431
What is the visible differences in the early VM28 carbs and the VM29? I almost sure both of them used the large screw on the carb bowls. So other than that how can I be sure I'm buying 29mm carbs and the similar 28mm carbs? Are there identifiable marking or numbers I should be looking for?
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • wireman
  • wireman's Avatar
Re: VM28 carbs vs. VM29 carbs
26 Oct 2006 05:28
#87434
look up at top of page,theres your 28s.;)
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
26 Oct 2006 08:24
#87492
The 29's have an insert in the bore(smoothbores)...
take a look at the pics,and You'll see what I mean...
1977 KZ1000 A-1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
26 Oct 2006 08:25
#87493
Pic 2
1977 KZ1000 A-1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
26 Oct 2006 08:25
#87494
Pic 3...
1977 KZ1000 A-1
  • 77KZ650
  • 77KZ650's Avatar
26 Oct 2006 08:35
#87500
Jeff has a good page about the different carbs, pics and descriptions click here
Scott
07 MDP Rookie of the Year
  • tw..
28 Oct 2006 15:07
#88085
Thanks guys. It looks like I got the 29's. It has the insert in the bore and it has 1.5 stamped on the top of of the slides. I think this confirms it.
thanks again.
2-1976 KZ900 A4
1978 Z1R
  • arobsum
  • arobsum's Avatar
28 Oct 2006 18:10
#88128
easiest way to tell is the 28's have 2 screws holding the lid on, while the 29's have 3 screws..and a 17mm nut on the bottom of the bowl.
