Sync screws,Where are they?
  • cnyl
  • cnyl's Avatar Topic Author
25 Oct 2006 19:05
#87348
Hey guys. I'm trying to help a friend out with his 76 Kz900.(carbs have MIK marked on them) I need to sync the carbs but I can't find the adjustment screws. Am I blind? lol I feel like an idiot!:blush: :)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  • vegasjetskier
  • vegasjetskier's Avatar
Re: Sync screws,Where are they?
25 Oct 2006 19:09
#87350
You have to take off the tops of the carbs. Remove the gas tank first.
  • cnyl
25 Oct 2006 19:17
#87355
I have the tank off. The screws are under the covers?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • vegasjetskier
25 Oct 2006 19:24
#87357
Are they Mikuni VM carbs? If so, the screws are under the covers. If your bike is like mine, there are 3 phillips screws per carb holding the covers on. Remove the screws, then the covers. You will see the synch screws inside the tops of the carbs. On my bike, the synch screws are held in place by locknuts. If yours is the same, loosen the locknuts, then you can turn the synch screws with a flat screwdriver.
  • cnyl
25 Oct 2006 19:28
#87359
vegasjetskier, Do I still sync 1,2 then 3,4 then both pairs together? Is there a screw to adjust both pairs?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • wireman
  • wireman's Avatar
25 Oct 2006 19:28
#87360
my bad i thought we were talking about that boy band gris managed back in the 90s :whistle: what?:P
  • vegasjetskier
25 Oct 2006 19:29
#87361
If you're really good, you can synch 'em with the gas that's in the float bowl. If not, you need to supply gas to the carbs while you do the synch. The easiest way to do this is to set the gas tank sideways on the seat and hold it down with some bungee cords. Use some extra fuel line to connect the petcock to the carb inlets. Hook up the carb synch gauges, then start the bike and turn the screws to synch them up. The engine needs to be warmed up to do it right.
  • vegasjetskier
25 Oct 2006 19:31
#87365
Not on my bike. You adjust them all individually. There's a screw for each carb. Adjust the one that's closest first, then adjust the rest of them to that one. Do you have a spec on the bike?
  • cnyl
25 Oct 2006 19:35
#87367
gris managed Nsync...LOL
I have an auxillary fuel ank that I use when syncing carbs. So basically your saying I do one carb at a time in order and NOT in pairs..
Cool!
Thanks. I feel dumb.:whistle:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • cnyl
25 Oct 2006 19:36
#87369
Spec? I have no manual.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • vegasjetskier
25 Oct 2006 19:37
#87370
Spec for my bike is 20 to 28 centimeters of mercury vacuum, with no more than 2 centimeteres of mercury difference between carbs at idle speed of 950 to 1050 rpm. I have VM26 carbs on my bike.
Post edited by: vegasjetskier, at: 2006/10/25 22:40
  • cnyl
25 Oct 2006 19:40
#87371
What are the specs for a non merc sync gauge?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
