Carb Spacing
- Exitpupil
Carb Spacing
19 Oct 2006 15:20
Is the carb spacing (bore center to bore center) the same on a KZ750 as on a KZ1000?
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- RomSpaceKnight
Re: Carb Spacing
19 Oct 2006 16:41
Yes it is. KZ650/750/900/1000 (not sure of 1100) and air/oil cooled GSXR's (possibly GS models too)all have same carb spacing. I am running 29mm smoothbores from a 1985 Canadian GSXR 750 on my 900/1000.
- steell
Re: Carb Spacing
19 Oct 2006 17:10
Yes the 1100 has the same carb spacing, I test fitted a set of GPz1100 throttle bodies on a GPz750 head the other day.
- Exitpupil
Re: Carb Spacing
19 Oct 2006 20:03
Thanks, that's what I needed to know.
