pod filters foe 650
  • lucas808
  • lucas808's Avatar Topic Author
pod filters foe 650
14 Oct 2006 05:41
#84185
im new to the kz. i just got my 1980 650 and am tryin to find some pod filters. the problem is that noone in my lovely LITTLE town can tell what size i need. can anyone provide me with alittle info? :blink:
  • KB02
  • KB02's Avatar
Re: pod filters foe 650
14 Oct 2006 06:43
#84194
Basically, you want to measure the outside diameter (OD) of the intake side of the carb and get a set that will fit over it.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
14 Oct 2006 07:28
#84210
Welcome. Pix of your bike are mandatory for all new members.
You'll find people will either be for or against pod filters. You can add me to the against side.
I found in everyday riding, I would have problems if it rained, as the outer two pods will get soaked. Then you'll be lucky if your bike will start. I ended up carrying a plastic bag with me to cover them up if rain was forecast.
Strong side winds would suck the life out of the engine. You'd get this blast of air, and the engine would bog down.
Most of the time my bike ran great, but after many years I switched back to the stock air bix with a K&N filter in it and have had no worries.
If your bike is going to be used just for an ocassional blast around town on nice days, pods may be ok for you.
If you plan on using her everyday, and you live in wet/windy conditions, I'd think twice.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • 77KZ650
  • 77KZ650's Avatar
14 Oct 2006 08:24
#84219
I think you need 39mm's, check out Z1Enterprises, or ebay
07 MDP Rookie of the Year
  • steell
  • steell's Avatar
14 Oct 2006 08:51
#84229
I have a set of K&N filters off a 1980 KZ650 in the garage somewhere, but the chances of finding them right now are pretty much zero.
I figure two or three more weeks and I'll be able to work in there again :)
