any help leaning mixture out?
- steveo_4192003
- 77kz650b-1
06 Oct 2006 10:01
my bike runs ok but needs to run better !it bogs on take off and once it goes (after 2 secs)it runs great, the real only problem it that it runs rich.(and looks like hell (gray primer)!
i tried to lean it out with adjustment but no luck, also played with the needle setting and no luck with that.
also took air filter out and it still ran rich
is there any other way to lean out with out getting smaller jets? i belive they are all stock, but as soon as i pull them (agian) ill get the numbers and confirm they are.
if it makes a diff, the timing is on and advancer is lubed pretty good and moves freely
p.s this is for a stock 77 650 b-1 carb set all stock
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- 77KZ650
Re: any help leaning mixture out?
06 Oct 2006 21:40
it could also be poor spark. check out the coil powering mod in the filebase or on wiredgeorges web site
link to article in filebase
Have sooty spark plugs? Backfiring? Rough running? Fiddled with the mixture screws on your carburetors till you are blue in the face? The problem MAY NOT be air/fuel mixture but a poor spark even though you have invested in new ignition components! Read on! Questions/comments on this article? lesho@bigfoot.com Cheers! wiredgeorge
07 MDP Rookie of the Year
