Fuel injection fitting problem
- pstrbrc
- '81 GPz 1100 project
28 Sep 2006 09:08
On the bottom of my GPz tank there is a return fuel fitting for the fuel injection. It appears to be a one-way valve so gas can return to the tank when the fuel pump is running, but not leave the tank when it's not. It appears to be made out of aluminum, with a brass valve and a steel spring inside. THe bottom of the tank I have was nasty, and my return valve was just plain ugly when I took it off the tank. I soaked it in vinegar for a couple of days, and all the crud came off the outside, but no flow through it, even w/90psi of air from my compressor. Anybody know how to free this one up? Any idea where I get a replacement for this? A new one from BikeBandit costs $34. Is that my only option? Yikes!
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- Lorcan
- Speed Loony
Re: Fuel injection fitting problem
28 Sep 2006 10:35
Stick a screwdriver in the hole and give it a tap. If it still won't free up, replace it.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
