Stumbles at highway speed.
- ran429
- Master of FREE rides!
23 Sep 2006 11:00
was wondering if unmodified carburetors with Pods would cause a Highway speeds stumble ?
Say like im doing 60-70 on the interstate and I have to reach down and set the choke to 1/4 or 1/2 so it will smoothe out a little and accellerate properly, but then when i come to a stop I have to reach back down and open the choke back up and it idles fine.
Just wondering ?
Going to try finding an airbox somewhere. Its the kz900 i am referring to here.
Just wondering ?
- RomSpaceKnight
Re: Stumbles at highway speed.
25 Sep 2006 20:42
Sounds lean. You have to enrichen mixture at speed and lean it out at idle. Go up at least 1 main jet size. Careful to lean at high speeds can be expensive.
- wireman
25 Sep 2006 21:30
bould be crosswind blowing air away from pods at highway speeds;)
- Biquetoast
- King Jeremy The Wicked
26 Sep 2006 04:55
wireman wrote:
By the way, did this symptom just start with new pods (or some other change) or was it always this way? If is was just the new pods, I'm more inclined to think about jetting...
One other thing to consider is fuel starvation. Try highway speed with the gas cap open/unlocked but lying closed. See if the extra air flow in the tank allows fuel to fill the bowls better...bould be crosswind blowing air away from pods at highway speeds;)
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- bemoore
27 Sep 2006 05:07
Does it only do it at highway speeds? Or does it do it at a specific RPM? If it does it at a specific RPM I would recommend setting the points. Mine would almost refuse to rev past 5500. I set the points (dwell & timing) and it revs a lot better. Not perfect, but a noticable improvement. I've got a new set of points on order and when they come in I'll be replacing them and the plugs.
77 KZ650C1 w/Kerker 4-1
