Carb size?
  • tullymars
  • tullymars's Avatar Topic Author
Carb size?
22 Sep 2006 04:44
#78681
Heres my setup,1075,10:25-1,stock valves,410 cams in,and ex.Now I need a set of carbs,34's or 36's?
  • racer54
  • racer54's Avatar
Re: Carb size?
23 Sep 2006 02:00
#78905
I'd go with the 34's. 36mm carbs might be a little too big. I was told 36's would be good for a 1200cc motor or there abouts. The 34's would be better for the street for sure. It would run ok with the 36's but I think you would give up some of your bottom end grunt for just a little(maybe) more top end power. Remember, you are still only 1075cc! Maybe someone here has your set-up and can give first hand advice, I don't, but know of others who have different set-ups and from what I've heard over the years. Bigger isn't necessarliy better when it comes to carbs.
  • kawtoy
  • kawtoy's Avatar
Re: Carb size?
23 Sep 2006 06:53
#78919
36's would be too big. As racer said you would lose bottom end but gain a bit in top end. How often are you going to be going full speed anyway? Everytime you pull away from a stop sign or red light you will be wanting the extra bottom end you will get from the 34's. You will have to ask George about jetting.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • wireman
  • wireman's Avatar
Re: Carb size?
23 Sep 2006 10:07
#78944
28-29s :whistle: ,allright her it comes!:P
  • racer54
  • racer54's Avatar
Re: Carb size?
23 Sep 2006 12:30
#78967
29's would be great if you had them. I love the ones on my 1075, but at the prices they are going for, I think the 34's would be the next best. I remember paying $300 for mine and I thought that was outrageous! Guess my "retirement investment" just keeps going up!
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: Carb size?
23 Sep 2006 12:33
#78970
I have 3 rebuildable sets off a late 70's 650.
they have the pumps under #2 I think it is.
  • tullymars
Re: Carb size?
25 Sep 2006 07:20
#79411
Well actually,I sold a set of 29's earlier this year,Ive wanted to try radial flat slides for some time just more modern,accelerator pump and all.George,any thoughts on jetting?
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Carb size?
25 Sep 2006 11:58
#79466
Sorry, can't help with radial flatslides. Suggest since you are buying them new to ask the seller as they should have some "standard" jetting set up for these carbs.
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: Carb size?
26 Sep 2006 17:44
#79863
If the cams where under 380 lift or there abouts I would say 29mm smoothbores (ummmm smoothbores, drool). 36mm for dragracing where the bike will only see part throttle for warming up back tire. I guess 34mm if that is only option left. The 29mm flatslides that came on early GSXR 750's (85 in Canada) can be bored to 32 or even 33mm and have same spacing as KZ's.
I am building a 1075 12:1 motor with 380 lift cams. Have been recommended 36mm for racing by local raceshop.
Post edited by: RomSpaceKnight, at: 2006/09/26 20:46
