carb kit for a 79 kz400??
  • mstbone67a
  • mstbone67a's Avatar Topic Author
21 Sep 2006 19:59
#78631
Sorry for the long first post.
Ok been reading and searching but seems to me that the kits come for a 77-78 or 80-81 but not for a 79
I have a 79 kz400 B2
Frame number is K-107744
Carb number is V55A QH08
I am not sure if the kit from the 78 will work..
I need the carb kit since buying the bowl gasket, and pilot screw seperately is pricey but If I have to .. I will.
I have to get the silver screw next to the pilot screw also and the rubber plugs inside the bowl.
I did find that someone had put a different float needle in.. one is all metal one is metal with the rubber tip.
ok so looking at the kaw parts diagram I am confused.
for the 79 b2 it shows 2 different mixture screws
16014-1001
16014-1009
Which is it..?
the 0001 part is used on
· KZ400 (1974)-->CARBURETOR PARTS (KZ400-D4) ('76 -'77 KZ
· KZ400-A1 (1977)-->CARBURETOR PARTS (KZ400-A2)
· KZ400-A2 (1978)-->CARBURETOR PARTS (KZ400-A2)
· KZ400-B1 (1978)-->CARBURETOR PARTS
· KZ400-B2 (1979)-->CARBURETOR PARTS
· KZ400-C1 (1978)-->CARBURETOR PARTS
· KZ400-D (1975)-->CARBURETOR PARTS (KZ400-D4) ('76 -'77 KZ
· KZ400-D3 (1976)-->CARBURETOR PARTS (KZ400-D4) ('76 -'77 KZ
· KZ400-D4 (1977)-->CARBURETOR PARTS (KZ400-D4) ('76 -'77 KZ
· KZ400-S Special (1975)-->CARBURETOR PARTS (KZ400-S3)
· KZ400-S2 Special (1976)-->CARBURETOR PARTS (KZ400-S3)
· KZ400-S3 Special (1977)-->CARBURETOR PARTS (KZ400-S3)
while the 0009 is used on:
· KZ400-H1 (1979)-->CARBURETOR PARTS
Notice that the 79 b2 is listed under both!!!
ok i pulled the needle out of the slide..
it has a 00300 on it
the jets are 95 and 35
does that ring a bell to anyone?
thanks
  • grace1
  • grace1's Avatar
Re: carb kit for a 79 kz400??
22 Sep 2006 01:15
#78675
g,day mate
carb kits on ebay this week
not sure of models though
cheers graemeB)
bendigo australia, gold mine country
MY COLLECTION 1978 B3 KZ750 AND 1980 GS1000G
  • mstbone67a
23 Sep 2006 20:10
#79079
Yeah gotta be specific one. Has anyone came across a 79 and been in the same situation?
thanks
  • JR
  • JR's Avatar
26 Sep 2006 16:45
#79843
I had a peek at Sirius www.siriusconinc.com/default.asp but dont see the 79 listed.
Have you loooked at www.kz400.com ? There'sa lot of usefull info there and if Ibsen does'nt have an answer for you I dont know who would
  • mstbone67a
26 Sep 2006 21:23
#79925
Yeah i have a thread over at kz400 and ibsen replied but didn't know for sure. even talked to z1enterprises about the mixture screw..
I am leaning to buying a kit for a 78.
