'79 SR650 carb replacement
- baja454
20 Sep 2006 18:18
I picked up a '79 SR650 cheap but it doesn't carburate good. Is there a better carb stup that would be better than the vaccuum style that is currently on it?
Thanks
Thanks
- kzwolfsr
Re: '79 SR650 carb replacement
01 Dec 2006 13:34
I cant believe no one ever answer this post. Its best to just rebuild it. You need to explain the symptoms of the bike and what its doing!
Original man of the Caribbean
- rstnick
01 Dec 2006 16:49
I missed this one.
Welcome baja454. As kzwolfsr said, you can salvage what carbs you have with a good cleaning and some new parts if needed.
Give us some more info on the bike. Lets us know if your using the stock set up, as in the factory airbox, exhaust etc., or have individual air filters (pods) and an aftermarket exhaust (type?).
Give us some pictures of your SR as well.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Bluemeanie
01 Dec 2006 18:54
The stock Mikuni's work very well in stock or modifided bikes. A good cleaning and a careful rebuild with proper jetting, etc will result in a smooth running machine
- pumps
01 Dec 2006 21:07
Welcome and before someone else says it. It is a good idea to put your model and year of your bike and your location in your signature. That will save questions on which model you have and maybe a member who is close can help you. your signature can be modified in your profile....How'd I do guys?
Oh yeah.I agree..maybe you can rebuild the old ones.
Post edited by: pumps, at: 2006/12/02 00:08
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
- SpokeWheel650B
01 Dec 2006 22:17Welcome baja454! As another new guy hear as well, I can say wholeheartedly that this is THE place to be.I picked up a '79 SR650 cheap but it doesn't carburate good. Is there a better carb stup that would be better than the vaccuum style that is currently on it?
Thanks
Sounds like your bike has CV carbs on it? Someone pulled the ol switcheroo as your SR should have the tried and true slide/needle type on it. The orig carbs are a cake-walk to tune and are plentiful on Ebay.
Good luck with her!
Ray
- kzwolfsr
03 Dec 2006 15:05
Tried and true barrel slides and needles with accelerator pump... like it does anything special and a vacuum sensor all on the no.2 carb body
