z1 jets?
- jcleach
z1 jets?
19 Sep 2006 15:18
74 z1 28mm smoothbores, emgo pod filters d&d race pipe
1150ft. altitude what jets should I start with?
- wireman
Re: z1 jets?
19 Sep 2006 16:24
ive got a set here with 125s in them,had 4n1 k&ns and a little ol set of pistons i my 74z1
- wiredgeorge
Re: z1 jets?
20 Sep 2006 05:50
Never saw a 28mm smoothbore so can't say what jets are needed. Clarify carb type.
- wireman
Re: z1 jets?
20 Sep 2006 06:06
damn i blew right past the word smoothbores there!:pinch: oopsies,did you mean 28s or are you talking about 29 smoothbores?:whistle:
- jcleach
Re: z1 jets?
20 Sep 2006 10:03
po called smoothbores, my bad .
I believe they are mikuni vm28's they measure 28mm at head side they are cast witk "MIC" on the side
- wiredgeorge
Re: z1 jets?
20 Sep 2006 11:43
If they are 28mm at the ID on the engine side, they are likely the original Z1A carbs. They will have a casting mark on the flange on each carb that shows:
147
3
In any case, they came with #112.5 main jets, #20 pilot jets and the 5J9-3 jet needles and largish needle jets.
These carburetors are relatively rich compared to later VM series carburetors so only a change in main jets to start... probably #120s. No other pilot jets are available as those pilots were only used on the 73/74 models that I know of. The jet needles MAY need to be reclipped since you have a race exhaust but I would WAIT till I had a chance to ride the bike and check for flat spots. The jet needles/needle jet combo actually has a richer mid-range than any other combo I can think of.
If you find a different casting ID mark than the one described, the info is not going to be relevant.
147
3
- wireman
