31mm flatsides?
- kawtoy
31mm flatsides?
11 Nov 2005 05:53
There is a set of 31mm flatsides here locally that should be able to get pretty cheap. They would go on my 1000 with 10.5-1 comp pistons, 4-1 pipes, accel coils, 410 cams. Anyone know much about these carbs? How would they work with my setup? Thanks
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- Fossil
Re: 31mm flatsides?
12 Nov 2005 17:55
I don't know off-hand what the size of your stock carbs are, but if the flatslides are the same size or larger, I would think you should see a performance increase. I find them very easy to work on and set up, and have not had any problem with them, other than a slide adjusting bolt/nut coming loose.
- GargantuChet
Re: 31mm flatsides?
12 Nov 2005 18:50
Keep in mind that if you go too big, you won't be able to pull enough air through the carbs to properly atomize the fuel. I don't know anything about the bigger bikes and carb sizes, but I just thought I'd mention that going too big can be apparently bad for performance.
- Fossil
Re: 31mm flatsides?
12 Nov 2005 19:56
31mm really isn't too big for a 1000. I'm running 36mm on an 1170, no problems.
- wireguy
Re: 31mm flatsides?
01 Dec 2005 20:00
check intake ports on your heads,stock ports work pretty good with 29s but check to make sure theyll work with the 31,if the ports are to small youll be causing more problems by restricting it!
- les holt
Re: 31mm flatsides?
02 Dec 2005 02:37
Got $5.00 says you will like them better than any carb that came stk on any 1000 kaw provided they aren't messed up. Had a built 750 with 29 smooths, broke it, put carbs on a stk 650 and it was pleasent to ride. Had a REALLY built 1196 with 34 smooths, broke it, put them on a stk 900, just a bit much. I would have to say, Go with them if they are in good shape and haven't sat for some time
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
