81 KZ1000M Gas leaking past float valve?
- Grantl
- KZRider is Da Bomb!!!
11 Sep 2006 13:20
Hi folks,
I recently tore down my carbs because gas was filling my airbox. From information given in previous posts I thought that my float seal seats might be pitted or have trapped gas tank gunk behind it. I completely cleaned out the carbs and tested the float valves by removing the valve housing and trying to blow through them while pushing on the little spring --loaded pin inside. When I reassembled the unit, I found that #4 still leaks out the overflow tube into the carb inlet boot.
All of the float valves seemed to hold pressure so now I'm wondering if the float tab might be not adjusted correctly to completely cut off the flow of gas or maybe the O'ring that goes between the carb housing and the float valve is leaking.
The other thing I'm considering is removing the stock airbox (huge pain in the ass to work around when removing or installing carbs) in favor of individual air filters mounted to each carb inlet. Your thoughts and opinions are very much appreciated.
Grant.
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- vegasjetskier
Re: 81 KZ1000M Gas leaking past float valve?
11 Sep 2006 14:58
Are you sure it's leaking out the overflow tube? The overflows on my bike come out the bottom of the floatbowls, not into the intake boots.
- steell
11 Sep 2006 15:44
I had the same problem (actually my brother did, but I have to work on his bike) with a 1982 KZ1000M. Only fix was to replace the float valves, and you can buy them at Z1 Enterprises. You can also get the carb to airbox boots from Z1, that will make removing and installing the carbs 100 times easier.
- Grantl
21 Sep 2006 11:49
I ordered a new float valve for carb # 4 and 4 new float valve o rings. I also purchased 4 individual K&N style air filters from ebay. I'm confident that I can repair the gas leak but now I need to know how to filter the air suction tube for the exhaust reed valve system. Is there a small filter I can install to make sure I have clean air going into the reed valve system? Also, where do I route the crankcase breather hose if I completely remove the factory airbox? Is it better to just buy original airbox to carb boots and stay with the factory setup?
Your thoughts and ideas are appreciated.
Grant.
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- Grantl
21 Sep 2006 11:50
Grant.
Grant.
1981 KZ1000 CSR
1990 550 Zephyr
1994 KZ1000 P
1990 550 Zephyr
1994 KZ1000 P
- ronjones
21 Sep 2006 13:27
Hey Grant, from info in previous threads, you need to either block off the reed valves or use a hose to route the valves together (I did the latter). You will also need to get a crankcase breather filter. You may have to rejet your carbs, also. There have been quite a few threads about doing this mod, in recent weeks. Probably one of the better wrenches will chime in and give a better explaination.
