Carburetor "pees" like crazy
- kz650sandrail
21 Aug 2006 21:01
My carburetors pee like crazy every time i turn on the fuel. It switches from one carburetor to another, Is this a stuck float? And how can i find out? I just cleaned all the carburetors. Could the only reason be a stuck float, or could it be something else?
Whats this for?
Post edited by: kz650sandrail, at: 2006/08/22 00:03
Whats this for?
- btchalice
Re: Carburetor \"pees\" like crazy
21 Aug 2006 22:24
the float might be stuck or the needle and seat are worn. the heedle has a rubber tip that wears out
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- wiredgeorge
22 Aug 2006 05:40
The needles on VM24 carbs don't have rubber tips. I would replace all four float valve assemblies.
www.z1enterprises.com
can help. Then I would set the float levels using the service fuel level method and last have a look at my web site (page for VM carb connections) for hooking the carbs up. The vacuum port is a giant air leak if not connected or capped.
- KawasakiBob
23 Aug 2006 16:14
I learned that the hard way :laugh:
- austin3119
24 Aug 2006 19:05
I'm kind of an idiot so take my advice for what it's worth. My carb was leaking real bad the other day. I hit the bowls of the carb with the handle of a screwdriver a few times and it doesn't leak any more. I don't know, it worked for me.
- Rickman
19 Sep 2006 11:13
this 'hammer' technique is documented in my Clymer. They point out the obvious fact that you have dislodged some piece of crap that was jamming something up, it is still in the bowl -- take the bowl off and get the crap out so it doesn't jam up something else.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
