float level to high = running rich?
- steveo_4192003
- 77kz650b-1
20 Aug 2006 16:17
ok i rebuilt my carbs and now they are running way rich.
ran great before but leaking
if my float level is to high can this cause my running rich problem????????
i belive i set them at 24mm dry (no means of wet test)
i will re set them agian!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
- mariozappa
Re: float level to high = running rich?
21 Aug 2006 06:02
You can do a wet test by taking a piece of 1/4 clear tubing from the hardware store, remove you drain plug from you carb bowl, insert the tubing (give it a couple of turns and it should hold and not leak).
Hold the tubing up against the side of the carb bowl...turn on the gas and the tube will fill up to the same amount that is in the bowl. Then you'll now for sure.
I'd try that before I took them apart again.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- steveo_4192003
- 77kz650b-1
21 Aug 2006 06:58
i know how to do it, and what needs to be done to set them wet! i will reset them
just wanted to know if the float level is to high , will this make it run rich?
- steveo_4192003
- 77kz650b-1
23 Aug 2006 12:03
i found it somewere on here, and said that float level may cause problems with the idle circut, and make it run poorly between the rpm range of 900 to 2000! and low revs
it this the right?
my bike runs poorly at idle and good at higher rpms, i have to get it up to 3000 before i take off or it wants to stall out, hot or cold. i belive its running rich on the idle circut! what causes this, float level right
once i hit 3000 rpms i good to go!
it this the right?
- saszta
29 Aug 2006 14:36
Float levels set too high will run it rich at idle and at small throttle openings and may be the source of your problem. I believe it will also run it rich in the rpm range you mentioned. The only thing to do would be to do the wet test and retry after your sure they're set correctly.
I hate that damned wet test myself as it is a messy process unless you figure out some 'clean' way to do it. I still haven't. Maybe doing it with water would be better but you'll have to blow out the carbs with some high pressure air afterwards to get it really dry - or put it under some heat lamps.
