Finally happened
- minutiesabotage
Finally happened
07 Aug 2006 20:39
I knew I was going to screw something up on this project.
I dropped my carb assembly from about 4 feet off the ground. (No BS excuses, 100% my fault) No damage except the drain of one of the float bowls snapped off. Can you buy new bowls or do I have to get new carbs?
Its not exactly a serious issue, but I can not test the float level on that carb.
- savedrider
- 1975 Z1-B 900
Re: Finally happened
07 Aug 2006 22:03
It's no biggie. I would look for a junker/parts set of carbs on eBay.
Get right or get left! <*{{{><
- btchalice
08 Aug 2006 04:30
you can still test the float level just use one off a different carb the float height shouldnt change with a different bowl
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
