  • Page:
  • 1
Ummmm. I don't know 07 Aug 2006 15:25 #67835
  • cnyl
  • cnyl's Avatar Topic Author
  • Thank you received: 5
Sometimes when I leave my 750 B4 sit for a few days, I go to start it up and it only runs on the left cyl. No gas visable in right inline filter. When I disconnect the hose from the inline filter(petcock side), gas runs out and I quickly hook the hose back up to the filter. It fills the filter and runs fine.
Is it vapor locking or something? I cleaned the vent hole in the gas cap the best I could. It's like I am purging or something.:pinch:
Post edited by: cnyl, at: 2006/08/07 18:26
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
Ummmm. I don't know 07 Aug 2006 15:36 #67839
  • minutiesabotage
  • minutiesabotage's Avatar
  • Thank you received: 0
Does your petcock have on/off/res or on/pri/res?
Ummmm. I don't know 07 Aug 2006 16:11 #67851
  • cnyl
It has on/off/res.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Ummmm. I don't know 08 Aug 2006 05:41 #67966
  • wiredgeorge
  • wiredgeorge's Avatar
  • Thank you received: 44
If you have hoses connected to the vent tubes, make sure they are clear and not kinked and if it still happens, try opening your gas cap to see if gas starts flowing. If the tank vent (in cap) is partially obstructed, opening the cap will allow you to pinpoint the problem to the cap. Gas will start flowing freely if the vents are plugged and you open the cap. Could be minor vaccum lock.
Ummmm. I don't know 08 Aug 2006 05:52 #67969
  • cnyl
Thanks george.
I opened the gas cap and nothing happened. I don't have hoses connected to the vent tubes so I wonder if the vent tube it self is clogged. Would it still run if so?
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  • Page:
  • 1
