popping in a carb?
  • timber
  • timber's Avatar Topic Author
popping in a carb?
06 Aug 2006 09:09
#67468
i am riding a 79 kz650d. i was out riding with a bud yesterday. all together i put on a little over 220 miles yesterday. the bike ran great all day. we stopped at his house for a soda an BS session. when i started back for home i had some popping in a carb. i thought maybe after it warmed up it would go away. well it didnt. i check my book and it said to check the timing. that checks out. it also said maybe bad gas but it seems to only be coming from one carb so i dont think that is right.
what do i check next?
thanks guys
  • baldy110
  • baldy110's Avatar
Re: popping in a carb?
06 Aug 2006 12:05
#67511
Does the popping come on right off idle only or at throttle settings? If it is right off of idle and the bike ran great all day I would say you have some dirt in the idle circuit. Usually popping back through the carbs is s sign of a lean mixture.
  • timber
06 Aug 2006 16:58
#67555
it pops at idle and half throttle. i did find that the number one and two carb boots loose. i tighten them up and it seemed to help alot. it still does pop. it will pop and run fine for a couple miles and then pop and be fine for 15 miles? its nothing i can get to do when i do this or that? maybe i have a boot starting to crack?
what is the wd40 thing? spray the boot and if the stops its the boots? but it has to be popping all the time right?
  • Wizzard
  • Wizzard's Avatar
06 Aug 2006 17:08
#67557
when you find an answer let me know I have not been able to figure it out either went for a 500km ride yester day and towards the end it was popin ever once awile as well bet runnin very well any ways.:S
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
  • timber
09 Aug 2006 19:58
#68420
update!
i went back and started checking everything. first thing was the timing. this time i checked with a dewll meter and not the feeler gauge method.
first off if you dont have a dewll meter get one.
even though the feeler gauge method said i was on. i was off by enough. set my time by the dewl meter. got it at 90 degrees and she came to life. now she is acting like a naughty little girl!:evil: :evil:
  • wiredgeorge
  • wiredgeorge's Avatar
11 Aug 2006 06:58
#68715
How does one check timing with a feeler gauge? Just curious...
