erratic idle
  • freebyrd24
  • freebyrd24's Avatar Topic Author
erratic idle
05 Aug 2006 23:47
#67409
ive been having problems with a real inconsistent idle. sometimes it idles fine, then goes up and downa nd its all over the place. i forget where it was, but i was reading about checking the intake boots and spraying wd40 to see if the idle changed. and it did change when i did that. so could my bad idle be bad rubber boots? even if they look ok?
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
  • freebyrd24
Re: erratic idle
06 Aug 2006 08:30
#67460
just an addition, this bike runs extremely well once it gets going and driving. takes a little while to warm up but when it does it is fast as hell all the way up to redline
Sold:
  • fixer5000
  • fixer5000's Avatar
Re: erratic idle
06 Aug 2006 15:37
#67542
bad intake boots can be deceptive for sure. try it agan and spray one at a time while it idles. dont be afraid to really soak it good...it wipes off . hold a bright light so you can see them closely. when theyre cracked they actually look like theyre breathing...cracks opening and closing. first time i did this test i was shocked at how many cracks they had...steve
1978 kz650b pretty much stock
massachusetts
