where is the gas going?
- Rev
05 Aug 2006 17:04
I put the original vm24 carbs back on the bike jetted with pods, and when I shut the bike off at night and come back in the morning, the float bowls are empty. I checked the floats and they are set right. There is no sign of any leaking from the overflow. My compression is 155, 160, 170, 160, and my valves are just set to proper clearance. I also have the bike on the center stand, so the bike is level to. Any ideas where the gas may be going?:blush: :dry: :S :S :blink:
78 kz650, Maxi-dwell, Modified flow through air box, Dyna coils.
- Wizzard
Re: where is the gas going?
05 Aug 2006 17:41
No idea but mine does the same thing evertime it sits for awile. Good question though.
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
- baldy110
06 Aug 2006 09:02
Your gas is going one of two places. Either it's evaporating out of the float bowls or it's going into your crankcase. I bet it's your crankcase. Does your oil smell like gas?
- Rev
06 Aug 2006 09:12
You may have some thing. The oil does have a slight gas smell, but how can it get into the crankcase, when the floats are set properly?
- hwms
06 Aug 2006 11:56
Floats may be set correctly but that does not mean that a float valve is not leaking.
- baldy110
06 Aug 2006 12:01
Even if the floats are set properly they can still leak. When I rebuild carburetors I alway wet set my floats. That way I know the needle is sealing and won't leak.
- Rev
06 Aug 2006 14:07
well the carbs are off and will wet test the floats tomorrow. Ill post the findings aswell. thanks
- Rev
07 Aug 2006 15:28
Well I checked the floats using the wet method, and all were in speck. with a 4oz syringe I put gas into the carbs.
I then left it to sit for awhile (30min)and it was down to the second line 60 min later it is down to the bottom line, and now holds there.thats a little less then 1.25 oz
There is no leakage from the overflow ports, or out of either side of the carbs, which eliminates the gas going into the oil.
will gas evaportate out of the float bowl vents that fast?
- Rev
07 Aug 2006 15:40
Ok now this is getting wierd:S I just went out and checked the level again and now it is rising. Gas expansion? I dont get it.
- baldy110
- Rev
07 Aug 2006 17:39
well the cv34's are back on the bike, and I'll be tearing these carbs down again and check the needles again. thanks for the help.
