bike only runs on choke
  • odl666
  • odl666's Avatar Topic Author
04 Aug 2006 16:53
#67178
1978 kz650 no air box. please help! screws on carbs one and a half turns out and only benched sync. thanks
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
Re: bike only runs on choke
04 Aug 2006 17:34
#67185
Only runs on choke. Sounds lean to me. Only runs when you choke off the air to the engine. Look for bad carb manifolds. Look for cracks and chunks missing. Have jets been changed to match lack of airbox. Try put airbox back on.
  • baldy110
  • baldy110's Avatar
05 Aug 2006 08:01
#67270
I will guess the bike sat for awhile? It sounds like the carbs need cleaning. The pilot jets are clogged.
  • wiredgeorge
  • wiredgeorge's Avatar
05 Aug 2006 08:15
#67275
Put some air filters on the bike and rejet appropriately. Bike is over lean because of no filters and stock jetting.
  • rek
  • rek's Avatar
08 Aug 2006 20:23
#68159
Listen to WG, he be the MAN!
The carbs on a 78 650 are not equipped with a REAL choke but an enrichment circuit that feeds more fuel to the engine while it is cold. same principal which is to enrich the mixture while cold but this doesn't restrict the air.
the pilots and needle jets may be stopped up or not but
those carbs won't run right until you put a stock air box on or some pods and jet for them no matter how clean the jets. (voice of experience);)
