Newbie idle problem question
- Wilde
05 Nov 2005 08:37
Hi all, just bought a 1981 kz750e which worked perfectly for two weeks, newly renovated carburators working fine. But....the idle was a little low so I turned the idle screw a little up getting correct idle but when I rev the engine and let go of the gas handle the idle gets stuck on around 4000 rpm. So I adjust down on the idle screw, revs a little and the engine stops. To low idle. Anybody got any ideas? thankful for any help.
- wiredgeorge
Re: Newbie idle problem question
05 Nov 2005 09:59
On your carburetors the cable fits into a cup type deal above throttle and the cable end is fitted into a slot. There is about 1.5 inches of exposed cable if memory serves. Now, up at your right hand switch gear where the cable comes out of the switch gear is a locknut and barrel adjuster. Loosen the locknut and turn the barrel adjuster toward you while looking at the 1.5 inches of exposed cable. There should be a bit of slack in the cable which I expect is not there now.
- Wilde
06 Nov 2005 01:41
Thanks for the help, I will check it and see if I can get it right.
Hm, I have tested, slack is OK now but still something seems to hang. I can adjust the idle but when I rev it up it sometimes get stuck at a high rpm....it is very strange, I am pretty sure that it is not the gaswire. Thankful for any more hints
Post edited by: Wilde, at: 2005/11/06 13:08
- Idaho_Spud
10 Nov 2005 08:57
A couple of easy checks:
You might try a little teflon-based lubricant in the cables and the exposed moving parts of the carbs. Also check for binding on your cables when the handlebars are hard right or left.
- Wilde
11 Nov 2005 00:53
Thanks for the tip, I kind of "solved" it by realising I had the choke lever in the wrong way (idiot mistake, I know). But thanks anyway
