gas out the exhaust?
- maddartist
30 Jul 2006 08:14
Me again, 1980-81 kaw 750ltd 4cyl
got the carbs to stop leaking,bought a second hand rack of keihns
now it seems like #1 cyl. isnt firing, boosted it with a battery pack last night and she ran shitty fer abit and leaked/sprayed gas outa the muffler.
now i got a clear inline filter should it be full of gas?cause its only half full.
Anyways i got a vac petcock and dont know if its the problem,i rebuilt it but dont know if i did it right.
What would cause it to start ,spit gas out the mufflers,and die then no start at all? the #1 exhaust pipe is cold,Is it the Petcock,coil or carbs? I got new plugs too!
this is pissin me bad, if ya can help me ,please i would be gratefull
- arobsum
Re: gas out the exhaust?
30 Jul 2006 09:05
sounds like the #1 carb is flooding into the engine. what does the plug look like?
- maddartist
31 Jul 2006 06:38
Plug is dry, how do i measure the volts at the coil to see if thats it?
thank you for the reply
- arobsum
31 Jul 2006 19:52
well, the wire will be green or black (i think). check the voltage there.
