gas leak from third carburettor hose
- pato
28 Jul 2006 19:01
Hi. in a kz 650 with two hoses from the petcock (I believe it is a 78)gas is leaking from the black hose that comes out from the bottom of the third carburattor (next to the big screw). I leave the petcock in the ON, facing down position,and it leaks, if I put it horizontal it leaks also.
it is not constant leaking. it "spits" a small mouthful of gas every so often (10/20 minutes or so). since I do not know what to do I just went and shoved a q-tip in the little hose to stop it wasting gas.
any ideas about what is causing the leak?
any ideas of what to do to fix it? thanks
- btchalice
Re: gas leak from third carburettor hose
28 Jul 2006 21:44
thats an overflow tube your float needle is sticking
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
- pato
29 Jul 2006 06:19
that helps. now, if the needle is sticking,
how do I get it unstuck, free? it will be in the 100s in the garage today, so I am hoping for some easy fix, like spray some stuff. just kidding:P :laugh:
thanks again
thanks again
- OKC_Kent
29 Jul 2006 06:29
Remove that big screw and drain the bowl, then remove the bowl, then you may be able to spray carb cleaner around the float needle area and free it up.
I have noticed over the time I have been on this forum, that a few riders have this little problem on the 3rd carb on a 650. I had it after I rebuilt my carbs, and once in a while it still pops up. I wonder if it is a design problem, maybe the float is hanging up on the carb bowl somehow?
Any way, don't shove a q-tip anywhere. Take the handle of a screwdriver and tap the 3rd bowl a few times to free it up, if you don't get around to cleaning it today.
Post edited by: OKC_Kent, at: 2006/07/29 09:30
Cashion, OK
78 KZ650 B2 85,000+ miles
- pato
29 Jul 2006 15:51
hi. I removed the bottom screw and it was like a jet with a hole inside, that was clogged. I cleaned that up and sprayed carburator cleaner. do you think that clog can cause an overflow? maybe the hot weather? thank you bothB)
- btchalice
29 Jul 2006 18:46
thats just a hole for the drain plug the float bowl is covering the float needle you need to clean you have to remove the 4 screws that hold the bowl on and clean the needle valve attached to the float
