KZ550 Pipes, Filters and Jets
  • Stvsnclr
  • Stvsnclr's Avatar Topic Author
27 Jul 2006 00:14
#65083
Hello, I'm new on the block. I have an '82 KZ550 B3 which I would like to outfit with some Vance & Hines pipes that I've located, and perhaps pod filters as well. I assume that some rejetting will be required but can't seem to locate any jets for that model/year. I'd appreciate any advice on the project and parts sources. Thanks
  • DasTeufel
  • DasTeufel's Avatar
Re: KZ550 Pipes, Filters and Jets
27 Jul 2006 06:29
#65103
Keihin 393 series jets fit perfectly in those TK carbs. I am using 100's in mine currently. Your local bike shop should have them.
2009 KTM 690 SMC
2008 Kawasaki Ninja 250R
2001 Suzuki GSXR 750
Wildomar, CA
  • Stvsnclr
28 Jul 2006 16:45
#65498
Thanks for the info Das, I'm well on my way. What exactly did you do to your pipes to make them "open stock"?
  • XSsiveone
  • XSsiveone's Avatar
14 Aug 2006 21:54
#69538
Are the Keihin jets sized the same?
Brian
  • wiredgeorge
  • wiredgeorge's Avatar
15 Aug 2006 07:40
#69590
I don't have the "series" numbers for the Keihin jets but the small headed "main" jets used on Harley "big twins" are an exact fit for the Tekei main jets. Don't get confused by Keihin terminology as these same jets will be used as "secondary main jets" which are really main jets. They use a double main jet system where the primary "main jet" is actually a jet that feeds/augments the jet needle in the mid-range. The real main jet is called a "secondary main jet" on the carbs with double main jets. The only differenc between the Keihin mains you will want to buy and a Tekei is the odd Tekei hex head shape. The sizes of the jet orifice and the pitch on the jet thread are identical. You will need to buy a rebuild kit for your bike to get the other jets and they will only be in stock sizes (pilot jets) as I know of no source for larger Tekei pilot jets.
