Won't Idle on all four - HELP!!! About to give up!!!
- pyxen
Re: Won't Idle on all four - HELP!!! About to give up!!!
19 Oct 2006 07:23
    that's tonight fun..I've been going through the thread piece by piece, its the one thing I haven't done.
      84 KZ550-F2 LTD
93 ZR550-B4
  93 ZR550-B4
- KB02
19 Oct 2006 13:04
    Alright.
I went ahead and blocked the hole up. I tapped it and used a small set screw. after resynching the carbs and adjusting the air screw, #4 is now firing like it's supposed to!!! YAY!!!!!!! :laugh: :laugh: :laugh:
That just leaves #1. Still same issue. Seems to run fine with a little throttle twist, but won't fire at idle. Hmmmmmmmmm....
Post edited by: KB02, at: 2006/10/19 16:05
- cnyl
19 Oct 2006 13:05
    KB02, Did you ever find out what the problem was?
Please share.
      Please share.
      1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  North Port, FL
Check out my band
- fishbone1
19 Oct 2006 14:31
    I have been following this thread. I think he almost has it.
- KB02
19 Oct 2006 14:50
    cnyl wrote:
Well, #4 seemed to be a missing part in the carb. As for #1. I'm not quite sure whats going on with that one just yet.
So, it looks like I have (had) two issues. They seem to have the same result, just different causes. One I have figured out.
More to come... I'm sure..
Please share.
- cnyl
19 Oct 2006 16:31
    Thanks for the update. I've been following along too.
      1982 KZ1000 M2 CSR
North Port, FL
Check out my band
  North Port, FL
Check out my band
- mark1122
- Keep twisting it
20 Oct 2006 02:31
    I had to remove all those brass bals to clean an old set of carbs once so I replaced them with tiny lead fishing weights .I just tapped them into the holes .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- KB02
20 Oct 2006 05:03
    I never thought of a fishing weight. That's a good idea.
The other good news is that "shake" effect is gone. That was the one that really bugged me. Now that I have figured it out, it makes sence. Shaking the bike caused the gas in the float bowl to wave back and forth, blocking up that hole temporarily allowing normal operation to resume for a second until the hole opened back up and extra air got back into the cuircut. Makes perfect sence in retrospec... :blush:
Now for #1. The low compression reading is starting to worry me now. By holding my hand on the back of the carb (choking it out a little bit) #1 will pop in. Still won't idle right, though.
- wiredgeorge
20 Oct 2006 06:16
    Glad you fixed the #4 carb. If you put your hand over the #1 carb and obstruct air flow, and it kicks in, the #1 carb is lean at idle. This means that the idle circuit is plugged. You mentioned you went through the carb cleaner drill but he fact remains, it isn't getting enough gas at idle. Adjust the air/fuel mixture via the air screw or reclean the carburetor. The bike isn't getting enough gas at idle and this can only be because of obstruction in the idle circuit or the air screw is misadjusted to my thinking...
- KB02
21 Oct 2006 05:42
    The cruel irony of all this is that just as I am getting this thing figured out, we got three inches of snow last night.
Who says God doesn't have a sence of humor?
