jetting \"standard\" kz 1200
- martijn
16 Jul 2006 13:02
has anyone a sugestion for jetting a bored 900 to 1200 cc. At this moment al standard except bored to 1200 cc (28mm carbs)
thanks Martijn
thanks Martijn
- donthekawguy
Re: jetting \"standard\" kz 1200
16 Jul 2006 14:28
You might want to start with around a 122 main. Do you pods, header and such?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- wiredgeorge
17 Jul 2006 07:21
Jetting kind of depends on WHICH 28mm carbs, what type airbox, what type pipes, what compression, what cams, non-stock porting and other issues. With no information to work with, any guess I could make would definitely be most likely wrong.
- martijn
18 Jul 2006 02:02
Hello George
All standard except the marshall 4 into 1 exhaust. The carbs are the standard 28mm.
What about the compression I think it is knocking!! due to standard cams etc with 1200cc???
- wiredgeorge
18 Jul 2006 06:09
They put VM28 carbs on Kaws in 73, 74, 75, 78, 79 and 80. Most all of them were jetted differently. To rejet, you must have a baseline. You have a stock airbox? Stock compression with 1200 pistons?
- martijn
18 Jul 2006 07:41
Yes, stock airbox and filter and wiseco pistons with specified compression of 1 to 12.25.
- wiredgeorge
19 Jul 2006 13:24
Well, without knowing the type of VM28, I am going to guess at jetting and say leave the jets in the carbs you have alone. If your pipes turn blue or the bike overheats, go up in size on the main and pilot jets.
