Cutting out at cruise
  • Sullivan
  • Sullivan's Avatar Topic Author
03 Oct 2026 11:37
#928194
Hey guys, cleaned and rebuilt carbs. 1978 LTD1000, VM26 carbs, pods and a kerker. 15 pilot, 113 main, needle in 2nd position {from bottom}. Carbs synched up nicely, fuel screws @1 1/2. Idles perfect, accelerates nicely all the way through. The issue I’m having is I can cruise at 35 mph seems fine, get out in the freeway and at cruise speeds 55-70 mph runs rough like its cutting out or like it’s dropping a cylinder or something . Gas it and it goes like it should. I would like to say it ran fine before but I’ve had this thing for a couple years and honestly can’t remember if it ever ran perfect. I bought another set of carbs and they ran very rich with the same set up. Any thoughts?
  • Sullivan
Re: Cutting out at cruise
05 Oct 2026 14:50
#928261
Nobody ever experienced this? Going to mess with fuel screws i guess. Right now they are all the same. Thought maybe spark plugs but that doesn't seem logical given that it runs great other than at that small throttle section. Hopefully I can get some input.
  • StreetfighterKz
  • StreetfighterKz's Avatar
05 Oct 2026 15:08 - 05 Oct 2026 15:09
#928262
Fuel screws really only are effective at idle. What needle is in the carbs and what clip (if grooved)?  You may want to search on here for “air adjuster jets” or something like that available from Zed1015, I believe.  They may help out the part throttle surging.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 05 Oct 2026 15:09 by StreetfighterKz.
The following user(s) said Thank You: Sullivan
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
06 Oct 2026 04:11
#928265
   Is fuel level at factory spec +/- 1mm?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Sullivan
06 Oct 2026 09:06
#928269
Well according to the tube method it is. Has to either be that or a needle issue I would think. Ill recheck float levels, which I assume you are referring to. Thanks for the insight.
