Intake boots
  • Maxbou92
  • Maxbou92's Avatar Topic Author
Intake boots
04 Sep 2026 13:49
#927286
Hello everyone, just wanna know if the intake boots have a specific location?! Can I screw the Left one on right side to have the vacuum in better position or Face down for synchronization? Thank youu
Kz750e 1980
  • zed1015
  • zed1015's Avatar
Re: Intake boots
04 Sep 2026 14:14
#927287
On the Z650/900/1000/1100 the manifolds are straight and can physically go in any position and orientation.
On the ones with brass vacuum ports it is only the ports position for ease of access which may determine their position.
  • Maxbou92
Re: Intake boots
04 Sep 2026 14:42
#927288
I ordered new boots for my vm28 with brass vacuum port like the old one.. the problem is that before I had to drill the rubber bolt holes to fit correctly the boots in the head.. just remove some material in the 2 holes of the boots to center them correctly!!?  The brass are face up. But Im wondering if I install them face down if its a good idea!?
Kz750e 1980
  • zed1015
  • zed1015's Avatar
Re: Intake boots
05 Sep 2026 00:53
#927293
Yes! elongate each hole slightly to fit the head and keep the manifolds central to the ports.
The stock position for the brass vac tubes is facing down and outwards for easiest access but it doesn't matter which way they go so put them wherever is convenient.
The following user(s) said Thank You: Maxbou92
