Pod filters on 82 GPZ550, a number of questions.
- Lord Osis
23 Aug 2026 19:53 - 23 Aug 2026 19:54
If you are familiar with the OEM airbox, you likely like me think it is a pain to service carb removal and installation.
I managed to find a clean set of carbs at a low price, which I bought despite the fact I have the originals (with stiff diaphrams, was going to get new ones) and found another set at a reasonable price from a used part dealer which appeared to be in good shape but need a cleaning.
This latest set came with individual pod filters, since the carbs were so clean I decided to mount them and see if my bike would start up, it hadn't been run in 30+ years. Over the years I would drop a little oil in the cylinders and crank it over, otherwise never started. The bike fired up and ran rough, no surprise, that's how it always did, and after warming up purred like a kitten.
I checked all the jets, they are stock, although I can't say they weren't drilled out. It idles and giving it some gas appears to run right, but the bike is not yet road worthy so didn't hit the streets.
Questions:
1) If I run it like this, what should I do with the EGR tube, it pulls air from airbox and mixes it with exhaust gas I believe?
2) What about the crank case vent which would normally vent to the air box and get sucked by the carbs?
3) Manual says to turn the air screw out how many turns you screwed in, obviously I don't know what the carbs originally were, but my 30+ year memory is 1 1/2 turns, which is what these were. Bike does idle smoother as i turn them out, 1 1/2 seems about right.
4) I have always heard that bike will not run with pod filters, too lean, but at least at idle and giving it gas from idle appears to run smooth, if it does run too lean at spped, where should I start.
I can always take the pods off and reinstall the OEM airbox, even though I'll cuss like a sailer doing it.
Questions:
Last edit: 23 Aug 2026 19:54 by Lord Osis. Reason: more precise
Re: Pod filters on 82 GPZ550, a number of questions.
23 Aug 2026 20:15
Your bike has air injection, not EGR. To remove, use a hose and connect the two ports on the valve cover, and plug any vacuum lines.
Running your bike with stock jetting and pods will result in a lean mixture. If the bike runs in this configuration, it will run hot, so don't do it.
- chopper1963
29 Aug 2026 10:25
Some of the threads here, now, are almost borderline masochistic.
You can buy new airbox boots on ebay for cheap.
- Buffalo BiL
31 Aug 2026 06:10
The GPz750 I bought had been in storage for 18 years. The previous owner had installed pod filters, but the foam had dry rotted away. The main jets he installed were #185. The bike started but I only ran it for 1 minute because it still had the old oil and gas.
I see pod filters as only useful for flat out racing and I have no intention of track racing this bike. I bought an airbox complete on ebay and restored the intake system as it came from the factory with #110 main jets. Runs great!
Bikes owned:
82 Suzuki GS1100G
87 Honda CBR600F Hurricane
90 Suzuki Katana 7/1100 conversion
85 Kawasaki GPz750
82 Suzuki GS1100G
85 Kawasaki GPz750
- H1Vindicator
31 Aug 2026 07:03
click the Lou's Legacy tab above. then click the valve train warning in any of his posts to get to his site. lots of 550 info and there may be jetting advice.
