Jetting
  • rwtylla
  • rwtylla's Avatar Topic Author
Jetting
13 Aug 2026 21:01
#926708
Hi guy's. I'm a newbie, just picked up a 74 z1, purchased it at sea level, I live at 6500 ft,  the runs out at 5000 rpm. I need to rejet the mains and was wondering if I can remove them on the engine or do the carbs have to be removed. The carbs are vm it's and the jets are in the bottom. Any thoughts. Thanks
Rob
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Jetting
14 Aug 2026 04:28
#926723
Welcome to KZRider
Your next post MUST be a introduction in our New Members forum
Site Moderator
  • asphalt900
  • asphalt900's Avatar
Re: Jetting
15 Aug 2026 02:29
#926762
The 1974 Z1 was a split year, early and late. Early carbs used float bowls with a big 17mm main jet access nut on each bowl. Later version only had a small brass drain slotted screw per bowl. Which version do you have?
  • rwtylla
Re: Jetting
16 Aug 2026 07:05
#926804
Sorry for the lateness of the reply, totally my fault. Anyway I have vm38's.
  • rwtylla
Re: Jetting
16 Aug 2026 07:09
#926805
Thanks for the heads up. All taken care of.
thanks
Rob
  • zed1015
  • zed1015's Avatar
Re: Jetting
16 Aug 2026 08:53
#926807
I'm sure you mean VM28's .
The following user(s) said Thank You: Warren3200gt
  • rwtylla
Re: Jetting
16 Aug 2026 13:01
#926810
There either a 38 or 39 there big mama's.  This engine is built. It's a 1087 cc with some nice size cams. . It hauls butt at sea level, but at 6500 ft it needs some different main jets.
  • zed1015
  • zed1015's Avatar
Re: Jetting
16 Aug 2026 14:00
#926812
I think you need to post some pics of the carbs you have to get the correct recommendations.
If they are a linked bank of four at 38mm they are not VM's but likely to be RS flatslides.
  • asphalt900
Re: Jetting
16 Aug 2026 14:33
#926813
YES, as Zed said, post some photos. Workin' in the dark here. But you said "nevermind" so does that mean you figured it out?
  • rwtylla
Re: Jetting
18 Aug 2026 07:00
#926854
I'll get out the build sheet . I'm gonna pull the carbs this fall and get into em.thanks for your help, I know more now than I did before. Thanks
