KZ305 Air box Boot Issue - 14073-1051 WORKAROUND
  • W2FH_HHH
  • W2FH_HHH's Avatar Topic Author
14 Jun 2026 16:36 - 14 Jun 2026 17:34
#924883
Attachment not found
My 81' KZ305 uses those stupid air box intake boots, part number 14073-1051. They are impossible to find anywhere, no NOS, no remans, nothing. For the past month and a half I've struggled to think of a workaround until I went to home depot and found these 1 1/2" rubber hoses. They fit the diameter of the air box holes perfectly as well as connect to the carb side perfectly. It creates a very nice seal on the air box side, I'd even go as to say better than the stock boots. Be aware that the boots need to be trimmed down a smidge to actually fit and have the same length as the stock boots.
The Home Depot part number is P1056-150. If you do not have access to a home depot, the actual company for the hose is called Fernco part P1056-150.
I hope to god people who are in the same boat see this.
Last edit: 14 Jun 2026 17:34 by W2FH_HHH.
The following user(s) said Thank You: JR, Flecca, potatozard
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: KZ305 Air box Boot Issue - 14073-1051 WORKAROUND
14 Jun 2026 17:21
#924884
Welcome to KZRider
Your next post MUST be a introduction in our New Members section.
Once done I will OK any further posts you make in this forum
Site Moderator
The following user(s) said Thank You: W2FH_HHH
  • Nerdy
  • Nerdy's Avatar
  • Away
14 Jun 2026 19:50
#924888
Glad you found that, but people have been using pieces of radiator hose for years :)
It's available in different sizes to fit a lot of different situations and is well-suited to high temps (even though a carb boot doesn't see all that much heat). They also might be cheaper than Ferncos
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Moderator
  • Moderator
16 Jun 2026 05:18
#924942
Awaiting introduction post before your post here will be oked
