Where is the diagram that shows butterly valves?
- spyshot
21 May 2026 05:17
I must me missing something. 1975 kz400d, I cannot find the parts diagram that shows the butterfly valves.
Any ideas?
Any ideas?
1975 KZ400
- StreetfighterKz
Re: Where is the diagram that shows butterly valves?
21 May 2026 07:17
They’re not available separately as far as I know. Not sure I’ve ever seen them separate in any parts diagram when I worked at a motorcycle shop for several years long ago. The screws are staked and not supposed to be removed from the throttle shaft.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
21 May 2026 07:49
- spyshot
21 May 2026 13:52
Thanks for that
1975 KZ400
- spyshot
24 May 2026 10:39
Completed the static sink. Putting back together and hopefully doing a vacuum sink today. But I have a question about this picture. One butterfly appears to be opposite of the another. Is this normal? Should I be concerned?
1975 KZ400
- asphalt900
24 May 2026 11:45
The RH carb butterfly is correct, little hole at the bottom. Someone has removed and placed the other one incorrectly. Remove and flip it BUT make sure the sharp edge coincides with the carb venturi. These butterflies are like a coin, heads or tails. They will "install' either way but only one way is correct. Look at the butterfly when you pull it. You'll note the angle milled into it. Make sure the other one is correct too. DON'T use pliers to pull it!! Just remove those two screws, flip shaft Wide open and wiggle it out with your fingers. Move throttle shaft back and forth when re-installing it, should fall into place. Lightly tighten both screws and blip the throttle shaft a few times to centralize everything then finish tightening. Should be an easy transition from Wide open to fully closed without any binding if done correctly.
- gd4now
- Denco where did you go?
24 May 2026 13:18
Not sure if any of this will be of help or not. But wanted to add a some service info from Kawasaki on these type of carbs. It explains what the small hole is for and lists stock settings.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: TexasKZ, kimchella
- spyshot
24 May 2026 16:35 - 24 May 2026 16:52
There is a marking on the butterfly. not sure what it says, but do you know if it is facing toward the engine or toward the filter? I think I understand what you mean about the sharp edge, but I just wanted to make sure.
Adam
Adam
1975 KZ400
Last edit: 24 May 2026 16:52 by spyshot.
- spyshot
24 May 2026 16:40
Thank you!
1975 KZ400
- spyshot
25 May 2026 07:35
Ok guys, Super Stoked! After the advice that I received on this forum, we were able to get this bike running and running great!
Here's a summary for those in the future who may want to know.
We've been fighting a high idle for months. I got the idle down by turning the pilot screws out 3 turns, but that just caused a rich condition and a false positive. Also BLACK spark plugs
So put the Pilots screws back.
One butterfly valve was installed upside down (by previous owner).
I was informed on this forum that that is not ok.
That got me on the track of looking over the valves' condition. Not only was one upside down, but it was nicked on the edge. The flashlight test revealed that the other butterfly was not round! I had extra carbs so I used the best two valves and reinstalled with the edge bevels facing the correct direction and little holes on the bottom.
I also had to stretch the spring on the sync adjust because it was not providing pressure when static synced.
I then static synced on the bench.
I then put it on the bike and vacuum synced (the best I could with my brake bleeder gauge.)
This thing runs great! We just went for a ride and I'm very happy. There are other small issues that I will start new threads about. But, Man, what a good feeling!
1975 KZ400
The following user(s) said Thank You: TexasKZ, Wookie58
