Need help with needle jet insertion
  • jwinatlanta
  • jwinatlanta's Avatar Topic Author
04 May 2026 15:28
#923655
Disassembled my Keihin cv34's for a complete drip and compressed air cleaning. That part is done. Now with reassembly I am not feeling good about re-inserting the needle jets into the carb bodies.
Seems they want to go in sideways. When I think i have them straight I go to tap them in with a flat punch it takes more effort than I think it should. Am I just too scared to whack it or am I missing something
  • Nessism
  • Nessism's Avatar
Re: Need help with needle jet insertion
04 May 2026 15:37
#923657
Sounds like they are misaligned during insertion.
  • jwinatlanta
04 May 2026 15:43
#923659
Any suggestions on how to get them in straight?
  • Nessism
  • Nessism's Avatar
04 May 2026 17:15
#923662
Drop the needle jet into the carb passage.  Use a tool, like a drift punch, to support it while you turn the carb right side up.  Look down the carb from the top, slide removed of course, and guide the needle jet up, so it properly aligns with the hole in the carb body.  Lightly tap the jet, making sure it doesn't cock and tilt, and push it into place.
The following user(s) said Thank You: H1Vindicator
  • jwinatlanta
05 May 2026 08:51
#923689
Maybe my age is catching up with me??? I've tried your method and it helps a good bit with alignment!!
Now is the "push it in" part. I push. I tap. I HIT IT! It doesn't seem to want to go in, I can hit it harder but I don't want to.
Maybe the jet is upside down? I don't think so. The roundish end  is headed into the venturi,
Am I just OLD???
  • Nessism
  • Nessism's Avatar
05 May 2026 09:35
#923692
Am I just OLD???
You have it upside down.  Round end facing float bowl.
  • jwinatlanta
05 May 2026 12:45
#923703
THANK YOU NESS I'm back together. I still have much to do.
