Yep, I in need of help....again
  • rickysnicker
  • rickysnicker's Avatar Topic Author
Re: Yep, I in need of help....again
15 Jul 2026 06:42
#925805
From what I have been reading here and several other websites, BS34 carbs are used on a lot of different bikes.  I found this website, www.cruzinimage.net/2018/07/23/80-83-yam...on-rubber-diaphragm/ with these slides and carbs.  Again, several other posters have had good results with this company.  Since these are for a BS 34 carb, I'm guessing they will work with my bike.  Opinions?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
15 Jul 2026 10:23
#925807
Check with the supplier for your specific model
  • asphalt900
  • asphalt900's Avatar
16 Jul 2026 04:17 - 16 Jul 2026 04:20
#925821
While you are correct, 34's were used on MANY makes/models and displacements, the slide itself differed Tremendously between them. Might check-out JBM Industries! They sell the diaphragm, just the diaphragm and nothing more. You simply snap off your retaining ring and remove rubber. The replacements merely stretch over your original slides. Paying mind of indexing the lift hole in slide to intake (cylinder head) side upon assembly. I've used their diaphragms for years.
Last edit: 16 Jul 2026 04:20 by asphalt900.
The following user(s) said Thank You: rickysnicker
  • rickysnicker
16 Jul 2026 06:24
#925822
I'm glad you mentioned them, as I looking at those.  As I was reading their website, they said measure the top of the carb, where the diaphragm sits.  Thinking all the BS34s were the same is bad, :).  Turns out, my carbs have the same measurement as the BS34SS carbs, 70mm.  They will be ordered today.  Did you use any glue to hold the diaphragm to the slide?
  • asphalt900
16 Jul 2026 07:23
#925825
I do but only after "tire" is installed. I pull back tire in just a couple spots (12oclock and 6oclock) and squirt just a drop or two of this stuff on slide channel. This is all that's required to keep the rubber from shifting. These type slides don't have slide channel and corresponding tab in casting slide bore, just a positioning tab on diaphragm rubber for correct installation. Note the little hole in bottom of slide, this hole as mentioned, faces towards engine during assembly. That little bit of superglue keeps everything in position. I use a gel type, slower setting time superglue. Better then the kwik setting type often found in hardware stores. Just my preference though.
  • rickysnicker
16 Jul 2026 09:40
#925829
Great, thank you for that bit of info!!
  • rickysnicker
22 Jul 2026 06:33
#926033
Since the carbs are off the bike, again (for like the 3rd time), I got the new diaphragms installed.  I also disassembled them, again, and shot carb cleaner throughout and into all the small orifices.  They are reassembled and waiting for Nessim's choke plunger donuts.  Those are the last parts that I can think of that have not be changed out.  I am really hoping that these things together will get these carbs and bike running properly.  The only other thing I have to check is an oil leak.
When it was running, there was coming from the right side of the oil pan.  There was a slightly loose bolt, so of course I tightened it.  Still had the leak.  Laying on the floor, I saw there was oil coming from the second igniton cover.  I am going to take that apart, but I suspect the oil seal back there, may have failed, causing the leak.   I highly doubt the oil pan gasket is the culprit.  We shall see.
  • rickysnicker
06 Aug 2026 06:11
#926510
I installed Ness' choke plunger donuts and new diaphragms.  Got the carbs on the bike and it still doesn't run for poo.  I've given up.  Thank you all for all the help.  I've called a local shop  to see if they can do anything to help me.  If that doesn't pan out I don't know what I am going to do with this thing.....
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Aug 2026 06:31
#926511
What is it "doing" or "not doing" ?
  • rickysnicker
07 Aug 2026 05:46
#926536
It won't idle and it won't stay running.  The only way it stays running is if I rev it to about 2k to 3k.
  • rickysnicker
30 Sep 2026 06:49
#928062
Finally!!!  After at least three months of screwing with the carbs, it's running and pretty well at that.  I tore the carbs apart, again, two days ago.  I took out all the brass parts, slides and diaphragms.  Shot them with carb cleaner and blew them out.  I bench synced them as well.  I don't know what I did differently than before, but it's running now.
It's a bit on the rich side.  I've tried adjusting the mixture screws, but when you roll the throttle, it hesitates a bit.  I will try adjusting them a tiny bit and see what happens.  I also used a vacuum carb sync tool to get them working together.  I am very pleased!!!  Thanks to all who responded and gave advice!!
The following user(s) said Thank You: Nessism, Wookie58
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
30 Sep 2026 07:41
#928065
Are you running the stock air box or pods ?
